Autor Tema: Hachiroku fest 2011 by demi76  (Leído 6515 veces)
« en: 24/11/2011 - 14:01 »
Os dejo el proceso de esta carrocería que es simplemente impresionante.
Pongo las citas del autor directamente, ya iré actualizando a medida que el actualice.
Primero os dejo el proceso del motor, que es lo que hizo antes.
Citar
hi all !
a long time ago I wrote nothing on this nice forum ...because I was losing a lot of time on the last project, but from the beginning how it all began :
 I thought one day .. why not make a copy of the engine?
 And so This it started ..
 1. Toyota Engine the gasket copied 4A-GE
2. material
3....... 2%   :P
4. .....
5. .....?
6. .......???
7. ... pistons
8.central shaft in 50%
9. wheel distribution
10
11.
12. timing belt
13.  spark plug caps
 14. ignition device
15. exhaust manifold
16. valve cover with 3D subtitles    :whoa:
17.  Card or two millimeters of styrene....
 heated and expanded profile 8 mm
 and water pump ...
18. heated in boiling water profile 6mm, was wrapped in the profile to 8 mm ...... and here is...... turbo
19.  The engine is ready in 80%, missing a few details and paint  .
20. is the time to show at the end of this project ,  after a long work , not sleepless nights     :idontcar:
this is the end  .... TOYOTA 4A-GE Engine ....( except  fitted to bodyshells )
also I did completed turbine with the blades
and the card oil change attached to the filter
a small movie as a working piston
http://www.youtube.com/watch?v=m_dmgG7AwsE
greet
Re:Hachiroku fest 2011 by demi76
« Respuesta #1 en: 24/11/2011 - 14:02 »
Y ahora la carroceria
Citar
Hello all!  :hi:
 Because I finished the engine 4A-GE ( http://www.hyperdrift.com/forum/viewtopic.php?f=12&t=6376 ) and must now be put somewhere, I started to 'beginning of a fun called  "hachiroku fest 2011" ...   :whoa:
 I'm working with a body  Trueno ( yokomo)
 hood cut
 I did the engine compartment in about 90% (missing a few details)
 on the chassis
 with body
 together
brake pump
 all together .... the reservoir with brake fluid  (thanks to Mr. Clean )
 radiator
 and case radiators with ventilator
 together with radiator
ham dashboard
 air grilles
 decorative frame
 speedometer
 all together
 glove box is opened
reinforcements to inner fender
 three images of the total chassis , there is still much to do  .... ufff
 shift lever, I had nothing to  round-head for shifter  head , so I decided to turning something to a piece of 4 mm round profile
 shifter ... I also turning
 components to make rubber protection
 All components for the shifter
 frame for shifter
shifter  gear complete
 thanks , to the next time guys   :byebye:
greetings
demi76
« Respuesta #2 en: 24/11/2011 - 14:02 »
Citar
thanks bro , thanks to all  :bow:
ok ... now I have dedicated myself to make some details such as plate under the battery, and to get the effect that is "pressed"
  I had to make two, one small and one slightly larger, then I glued together and come up with something similar in pressed .
battery retainer... smallest in the world  :whoa:
 all complete
 Battery  ...... no comment's  :likethis:
turn stops of the battery, the battery can be removed
part to the tank
 and wiper motor
greetings
demi76
« Respuesta #3 en: 24/11/2011 - 14:39 »
Creo que ya lo vi hace tiempo, almenos lo del motor. Una pasada realmente!
« Respuesta #4 en: 24/11/2011 - 17:37 »
Impresionante. No lo ha acabado o qué?
« Respuesta #5 en: 24/11/2011 - 17:43 »
Yo creo que lo del motor también lo vimos por aquí hace un tiempo...
La verdad que lleva buen curro!
« Respuesta #6 en: 24/11/2011 - 17:58 »
Adiós Dios, hola Demi76!
« Respuesta #7 en: 24/11/2011 - 18:42 »
Aun no lo a acabado, iré poniendo mas avances si los pone
« Respuesta #8 en: 21/12/2011 - 14:45 »
Citar
Thanks guys  :bow:
ok. guys, I worked a little ', and now you can see as it takes shape, but still a lot of work.
 had to turning the lever to switch under the steering wheel
 photos as I started working with the steering wheel ...  :whoa:
 ... and here it is .... steering wheel and switches ready  :dead:
 the ignition key with key chain  :hehehe:
 the pedals
 hand-brake lever
 all together
 the work is on hold .... I do rest of the work after Christmas.
 I wish to all Merry Christmas  :peace:
greet
demi76
« Respuesta #9 en: 21/12/2011 - 15:05 »
Es que simplemente es flipante...
« Respuesta #10 en: 19/02/2012 - 19:06 »
Ya ha terminado el coche, a ver si se crea una nueva pagina y sigo poniendo fotos
« Respuesta #11 en: 20/02/2012 - 09:35 »
TORRENTE
  • AUDI A4 AVANT S-LINE....
  • WEAH!!!
Vaya currazo, aunque a 1/10 no tiene nada que ver con 1/24 por ejemplo, pero me encanta como trabaja el Evergreen.
Supongo y espero que sea un coche de demostración, después de semejante currazo solo le falta estamparlo y destrozar esa obra de arte...
Esperando fotos del proceso final.
PD: Había uno a 1/24 que tenía el mismo proceso, ahora no encuentro el enlace...
« Respuesta #12 en: 20/02/2012 - 09:40 »
TORRENTE
  • WEAH!!!
« Respuesta #13 en: 20/02/2012 - 12:24 »
ufff vaya curro tiene ese!
Vamos con las ultimas fotos!
Citar
Hi guys,
 Here is another part of my sickness  :whoa:
 As I decided to open the bonnet and I said A,  why not say B and open the door.
 I had some problems and I finally abandoned the idea of ​​making the handles and door locks, because unfortunately when I tried to open up a second time I broke everything ... :dead:
 handle to lift glass
 handle
 Japanese registration certificate
 My new license.......of course Japan ...
 Japanese battery ...
 I did not like  wipers as standard, as to the presents
 and I did  ​​my own
 I have a few yen, if someone can trade  to the euro / usd ...no problem   :hehehe:
small preview what it looks  everything
 I did everything by hand, in addition to the seats .
greet and thanks , to the next time guys  :byebye:
Citar
Hi guys,
  Today is the day when after a year and four months I can finally finish this project .... and go for retirement ...hihihi  :hehehe:
  The inspiration for this body was the Pace Car AE86:
http://farm8.staticflickr.com/7028/6514772761_71a0ddde90_o.jpg
- Body: Yokomo AE86 Trueno
- Chassis: TT-01D
- Body paint (PS-2, PS-5, PS-34, PS-55)
- Chassis paint: primer surface, TS-8, PS-2, XF-16, XF-1, X-27, X-26
- Graphics: club stickers on the windows-  homemade
- Wheels: HPI Work Meister S1 +6 mm Offset Chrome
- Tires: HPI Radial Tire
- Accessories aesthetic "commercial": mirrors (HPI), lightbuckets Droo-P AE86 Yokomo
- Custom Accessories Beauty: Everything made by hand from  engine to internal ,  and if I have to specify the missing page.
- Extras: as written above..... many .....
  Do not write anything more, it makes no sense, because everything there' you can see on the photos.
 Comments and critique welcome
Thanks for the time spent together ,   best regards   :bow:
demi76
Venga, hasta luego.
« Última modificación: 20/02/2012 - 12:24 por samu »
« Respuesta #14 en: 20/02/2012 - 15:07 »
Es curioso de ver.
