Autor Tema: RadioControl!  (Leído 183772 veces)
Re:RadioControl!
« Respuesta #390 en: 15/07/2011 - 01:34 »
cuando esté pintada pondré fotos, transparente no se aprecia xD
Mirad esto
Re:RadioControl!
« Respuesta #391 en: 15/07/2011 - 12:06 »
Re:RadioControl!
« Respuesta #392 en: 15/07/2011 - 12:11 »
Re:RadioControl!
« Respuesta #393 en: 15/07/2011 - 13:37 »
Un alfiler como pomo, que detalle mas original (irónicamente hablando):sisi3:
Re:RadioControl!
« Respuesta #394 en: 15/07/2011 - 13:38 »
No se puede ver ese enlace, hay que registrarse... nomola!
O nos dejas tu cuenta para ver ese foro o cierro este post!
RadioControl!
« Respuesta #395 en: 15/07/2011 - 13:48 »
Es el fallo que tiene el S15, es brutal entero menos el alfiler que nisiquiera lo a pintado.
Esto es lo del enlace que no podéis ver.
Citar
hi all !
a long time ago I wrote nothing on this nice forum ...because I was losing a lot of time on the last project, but from the beginning how it all began :
 I thought one day .. why not make a copy of the engine?
 And so This it started ..
 1. Toyota Engine the gasket copied 4A-GE
2. material
3....... 2%   :P
4. .....
5. .....?
6. .......???
7. ... pistons
8.central shaft in 50%
9. wheel distribution
10
11.
12. timing belt
13.  spark plug caps
 14. ignition device
15. exhaust manifold
16. valve cover with 3D subtitles    :whoa:
17.  Card or two millimeters of styrene....
 heated and expanded profile 8 mm
 and water pump ...
18. heated in boiling water profile 6mm, was wrapped in the profile to 8 mm ...... and here is...... turbo
19.  The engine is ready in 80%, missing a few details and paint  .
20. is the time to show at the end of this project ,  after a long work , not sleepless nights     :idontcar:
this is the end  .... TOYOTA 4A-GE Engine ....( except  fitted to bodyshells )
also I did completed turbine with the blades
and the card oil change attached to the filter
a small movie as a working piston
http://www.youtube.com/watch?v=m_dmgG7AwsE
greet
Re:RadioControl!
« Respuesta #396 en: 15/07/2011 - 13:50 »
Te doy 2 horas para que podamos entrar a la página... sino... "BOOOOM!"
Que estoy mu loco.
PD: El s15 tiene muchos detalles, pero no creo yo que corra mucho con ese coche porque al minimo golpe se le caerán las llaves del capó y el otro es original, mola.
Re:RadioControl!
« Respuesta #397 en: 15/07/2011 - 13:52 »
Novedad y tal... :facepam:
Re:RadioControl!
« Respuesta #398 en: 15/07/2011 - 13:54 »
Impresionante!!! jooder como se lo ha currado el tio, me he quedado sin palabras, ese tio es el puto amo.
Re:RadioControl!
« Respuesta #399 en: 15/07/2011 - 14:58 »
Las dos carrocerías muy chulas.
+1
RadioControl!
« Respuesta #400 en: 17/07/2011 - 12:57 »
Re:RadioControl!
« Respuesta #401 en: 17/07/2011 - 14:57 »
Que pasote el motor "Hand Made"!
Re:RadioControl!
« Respuesta #402 en: 17/07/2011 - 18:06 »
Al del E30 le he preguntado si el motor es artesanal, de ser así es un curro curioso también
Re:RadioControl!
« Respuesta #403 en: 17/07/2011 - 18:29 »
Convertirlo en pickup :facepalm:
Turbiar un E30 :facepalm:
Cambiarle el motor a un M3 E30 :facepalm:
Que motor lleva? :S
Re:RadioControl!
« Respuesta #404 en: 17/07/2011 - 18:36 »
Parece que a intentado hacer el de un M3 E36 o E46, está super currado, si no fuese PickUp seria la caña, el vano motor esta super detallado y fijaos el baket xD
